cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: davidpwolf (simulated) on 15-08-2013 04:52:19 PM
I'm working with a C40 and Crestron would like to sent commands to the C40 to configure audio output line 1 and line 2 be connected to the Audio Output LocalOutput 5 Name: "recorder", and also like to send the HDMI audio input and Line audio input to the "Recorder". This will allow me to send this audio to an over flow room so they can hear the near and far end audio, since they will not have a microphone in the overflow area just observe the conference.
I would like the crestron to send commands to configure this so we do not have to use TC console if the unit is replaced or the setting are cleared with a firmware load.
Is this possible?
David
