Muhammad Raza
Level 7
Level 7
Note: if facing problem, avoid to copy paste these queries. 🙂
1. Check active scripts
select * from Master_Script
2. Check total number of active scripts
select count(*)from Master_Script
3. Check Call records in ICM database (RCD table) using ANI
Select * FROM Route_Call_Detail WHERE  ANI='replacewithNumber'
Select * From Route_Call_Detail
WHERE ANI LIKE '%replacewithNumber'
--WHERE ANI LIKE '%replacewithNumber'
AND DateTime > '5/2/2016 8:00:00'
SELECT DateTime, Variable9, Variable10, Variable5, Variable6
WHERE ANI Like '%replacewithNumber'
4. Check Call records in ICM database (TCD table) using ANI
Select * FROM Termination_Call_Detail WHERE ANI='replacewithNumber'
5. Check Dialed Number, Call Type and Scripts mappings
Select Dialed_Number.DialedNumberString,Dialed_Number.DialedNumberID,Call_Type.EnterpriseName As CalltypeName,Call_Type.CallTypeID,
Master_Script.EnterpriseName As ScriptName,Master_Script.MasterScriptID
from Master_Script, Call_Type_Map, Call_Type
, Dialed_Number_Map, Dialed_Number
where Master_Script.MasterScriptID = Call_Type_Map.MasterScriptID
and Call_Type_Map.CallTypeID = Call_Type.CallTypeID
and Call_Type.CallTypeID = Dialed_Number_Map.CallTypeID
and Dialed_Number_Map.DialedNumberID = Dialed_Number.DialedNumberID
order by Dialed_Number.DialedNumberString
6. Check Scripts and Skill Groups mappings
Select Master_Script.EnterpriseName as ScriptName, Master_Script.CurrentVersion, Script.Version, Skill_Group.EnterpriseName as SkillGroupName From Master_Script Join Script ON Master_Script.MasterScriptID = Script.MasterScriptID Join Script_Cross_Reference SCR ON SCR.TargetType = 2 and SCR.ScriptID = Script.ScriptID, Skill_Group Where Master_Script.CurrentVersion = Script.Version and Skill_Group.SkillTargetID = SCR.ForeignKey and Master_Script.CurrentVersion = Script.Version
7. Check script related configurations using query, Replace text with script name *(Replace with Script Name)
SELECT TargetType,
       XR.ScriptID , MS.EnterpriseName as Script,
       SG.SkillTargetID, SG.EnterpriseName as Skill_2,
       CT.CallTypeID, CT.EnterpriseName as CallType_7,
       ESG.EnterpriseSkillGroupID, ESG.EnterpriseName as EntSkill_9,
       REG.RegionID, REG.EnterpriseName as Region_10,
       R.RouteID, R.EnterpriseName as Route_17,
      MSC.MasterScriptID, MSC.EnterpriseName as MSEntName_20,
       UV.UserVariableID, UV.VariableName as Variable_31,
       UF.UserFormulaID, UF.EnterpriseName as Formula_32,
       VRU.NetworkVruScriptID, VRU.EnterpriseName as VRU_33,
       ECC.ExpandedCallVariableID, ECC.EnterpriseName as ECC_37
FROM Script_Cross_Reference XR
  INNER JOIN (
  SELECT iSC.ScriptID AS ScriptID, iMS.EnterpriseName, iMS.CurrentVersion
    FROM Master_Script iMS
      INNER JOIN Script iSC ON iSC.MasterScriptID = iMS.MasterScriptID AND iSC.Version = iMS.CurrentVersion
-- Plug in your Script name in the next line...
    WHERE (iMS.EnterpriseName LIKE '%Replace with Script Name%')
    GROUP BY iSC.ScriptID, iMS.EnterpriseName, iMS.CurrentVersion)
    MS ON MS.ScriptID = XR.ScriptID
  left OUTER JOIN Skill_Group SG on SG.SkillTargetID = XR.ForeignKey and XR.TargetType = 2
  left OUTER JOIN Call_Type CT on CT.CallTypeID = XR.ForeignKey and XR.TargetType = 7
  left OUTER JOIN Enterprise_Skill_Group ESG on ESG.EnterpriseSkillGroupID = XR.ForeignKey and XR.TargetType = 9
  left outer join Region REG on RegionID = XR.ForeignKey and TargetType=10
  left outer join Route R on RouteID = XR.ForeignKey and TargetType=17
  left outer join Master_Script MSC on MasterScriptID = XR.ForeignKey and TargetType=20
  left outer join User_Variable UV on UserVariableID = XR.ForeignKey and TargetType=31
  left outer join User_Formula UF on UserFormulaID = XR.ForeignKey and TargetType=32
  left outer join Network_Vru_Script VRU on NetworkVruScriptID = XR.ForeignKey and TargetType=33
  left outer join Expanded_Call_Variable ECC on ExpandedCallVariableID= XR.ForeignKey and TargetType=37
ORDER BY MS.EnterpriseName, XR.TargetType;
8. Primary Handled Call Count
select Count(CallDisposition) As PrimaryHandledCallCount from Termination_Call_Detail where CallDisposition in (13, 52) and DateTime>='02/09/2016 00:00' and DateTime<='02/09/2016 13:03'
9. Abandoned in Network Flag Count
Select Count(CallDisposition) As AbandonedinNetworkFlagCount from Termination_Call_Detail where DateTime>='02/09/2015 00:00' and DateTime<='02/09/2015 13:17' and CallDispositionFlag = 1
10. Abandoned Delay Count
Select Count(CallDisposition) As AbandonedDelayCount from Termination_Call_Detail where DateTime>='02/09/2015 00:00' and DateTime<='02/09/2015 13:29' and CallDispositionFlag = 4
11. Call_Type Count & Enterprise Name / Skill Group Count & Enterprise Name
select count(*) from Call_Type
select EnterpriseName from Call_Type
select count(*) from Skill_Group
select EnterpriseName from Skill_Group
12. Retrieve and use Column Tile for values
Select
 r.DialedNumberString AS [DNIS]
,r.ANI
,r.DateTime
,r.RouterCallKeyDay
,r.RouterCallKey
,r.Variable3 AS [LineOfBusiness1]
,r.Variable4 AS [LineofBusiness2]
,m.EnterpriseName AS [Script Name]
FROM pic4_hds.dbo.t_Route_Call_Detail AS r
JOIN pic4_awdb.dbo.t_Script AS s ON r.ScriptID=s.ScriptID
JOIN pic4_awdb.dbo.t_Master_Script AS m ON s.MasterScriptID=m.MasterScriptID
Where r.ANI =''replacewithNumber''AND r.DateTime BETWEEN '2015-12-07 12:56:00'AND '2015-12-07 13:00:0'
13. For Presistent Variable value in Logger (run on Logger Db)
select * from Persistent_Variable
select * from User_Variable
select
User_Variable.VariableName,
Persistent_Variable.ValueInt,
Persistent_Variable.ValueFloat,
Persistent_Variable.ValueChar
From
User_Variable INNER JOIN Persistent_Variable ON User_Variable.UserVariableID = Persistent_Variable.UserVariableID
SELECT uv.ObjectType, pv.ValueInt, uv.VariableName, pv.ValueChar
FROM Persistent_Variable pv, User_Variable uv
WHERE pv.UserVariableID = uv.UserVariableID
ORDER BY uv.VariableName DESC
14. Cisco Outbound Dialer Campaign Results (Use instance_awdb)
To find the campaign ID use (select * from Campaign)
select Phone, PhoneID, FirstName, LastName, AccountNumber, CallResult, DateTime from Dialer_Detail
WHERE DateTime between '01/01/2023 00:00' AND '01/02/2023 23:59'
AND CampaignID = 'replacewithcampaignID'
15. Check Total number of Agents Loggedin
SELECT COUNT(*) AS TotalLoggedInAgents FROM Agent_Real_Time
16. Check Total Number of Agent with First and Last Name, Full Name, Login Name, Extension and current Agent State Code.
SELECT
    P.FirstName,
    P.LastName,
    P.FirstName + ' ' + P.LastName AS FullName, -- Combines first and last name
    A.EnterpriseName AS LoginName,
    ART.Extension AS CurrentExtension,
    ART.AgentState AS AgentStateCode
FROM
    Agent_Real_Time ART
INNER JOIN
    Agent A ON ART.SkillTargetID = A.SkillTargetID
INNER JOIN
    Person P ON A.PersonID = P.PersonID;
salman.razi
Community Member
used many of these queries in my cut-overs
Thanks Amir... Keep up the good work 🙂
Chandhya
Visitor
Hi Amir, Is it possible to get list of all user variables and their associated script names using Database query?
pchaudhary2000
Community Member
Nice Work!!!
could you provide agent SQL queries
imran.mestri1
Frequent Visitor
Frequent Visitor
awsome job !!
