Jun Zhu
Does anyone know how to upgrade the 6900 series firmware from a PC using tftp and dhcp server software?
Is there a step by step process?
TIA.
Aman Soi
You can use the link :
https://supportforums.cisco.com/docs/DOC-23730
regds,
aman
Jun Zhu
thanks aman, does it applicable to 6900 series ip phone?
I used to upgrade the 7900 series by tftpd successfully, but 6900 series seems different.
Aman Soi
Hi Jun,
I have never tried on 6900 series .Did u try to upgrade 6900 series and facing some problem.?
Thought the procedure would be same as 7900.
regds,
aman
Jun Zhu
Hi aman,
yes, I tried to flash a 6921 ip phone with the same process of 7900 series, but the 6921 has no response even did not get the ip address correctly.
