Rajiv Lal
This Document will help in accessing database tables of UCCX which has MSDE running.
Kindly see the attached file.
Anthony Holloway
or you could use your command line foo
osql -E -S HOSTANME\CRSSQL -Q "USE db_cra SELECT teamID, teamName FROM Team WHERE active = 1"
Thanks for the tip
great doc
only i need to ask about these 2-steps:
àOn the server running SQL create a user and assign it to admin group.
àOn the UCCX box create the same user and assign it to admin group
first on SQL: this mean creating a windows admin local user
second on uccx: this mean also a windows admin local user , or ipcc user have admin priviliges
So can i use the current administrator user of the uccx windows machine without creating new one?
