Geovani
Introduction
CDA is a Cisco Cloud provisioning platform used for Zero Touch Provisioning. It automatically provisions the device out of the box and provides a “plug and play” user experience.
Behind the scenes
  1. Service Provider/Distributor creates a Profile before / during the order process to ensure all the MAC addresses get automatically mapped to the profile when order is shipped.
  2. Once customer receives the device and plugs into the network, device calls Cisco Cloud/RC EDOS server.
  3. Cisco Cloud looks up profile based on device’s MAC address, then provides profile to device.
  4. Device is redirected to the SP Provisioning Server.
  5. SP Provisioning Server provides configuration information to device
Sample EDOS Configuration Profile
<?xml version="1.0" encoding="UTF-8"?>
<device>
<flat-profile>
<Primary_DNS>12.45.67.89</Primary_DNS>
<Provision_Enable>Yes</Provision_Enable>
<Resync_On_Reset>Yes</Resync_On_Reset>
<Resync_Periodic>7200</Resync_Periodic>
<Resync_Error_Retry_Delay>30</Resync_Error_Retry_Delay>
<Profile_Rule>http://yourserver.com/$PN/$PSN.xml</Profile_Rule>
</flat-profile>
</device>
Device Profile Setup Flow
Account Setup
Use cisco.com credentials to login to CDA web portal (https://software.cisco.com/software/cda/home) and request “Distributed Customer” role
Create a profile
  1. Login to https://software.cisco.com/software/cda/home using your Cisco account
  2. Navigate to Profile Management and Add Profile
  1. Select the appropriate PID
  2. Select “Create a New Profile”, enter the profile name, upload the profile xml file and click on Add Mapping”
Associate a MAC Address to the Profile
  2. Navigate to MAC Address Management
  3. Enter a MAC Address and click on Validate
  4. When you click on Validate, a pop-up window will appear. Select the MAC Address and click on Proceed
  5. Select the profile name and click on Submit
IP addresses that are used on EDOS/CDA for whitelisting purposes
Whilst we don't generally recommend whitelisting by IP address/subnet in case of changes to the IP addresses behind the DNS domains used, it is understood that this is a requirement for many SPs.
Two domains are active for EDOS/CDA, activate.cisco.com and webapps.cisco.com.
Subnets for activate.cisco.com:
72.163.10.96/27
72.163.15.64/26
72.163.15.128/26
72.163.24.0/23
173.36.127.0/26
173.36.127.128/26
173.37.26.0/23
173.37.149.96/27
192.133.220.0/26
192.133.220.64/26
Subnets for webapps.cisco.com:
72.163.10.128/25
173.37.146.128/25
These ranges are subject to change at any point in time, so make sure that you subscribe to the notifications in the EDOS/CDA services so that you receive any notifications about subnet changes - it's the same notification service that informs about EDOS/CDA planned outages etc.
jk399
@Geovani  Wondering if you can advise: If you purchase refurbished Cisco 8800 series IP Phones that were previously enrolled in CDA/EDOS by the old owner's carrier, is there any way of removing this or telling the phone to ignore? After doing factory resets, the phones snap back to the old carrier (8x8 Inc) provisioning server. Ironically, we're trying to activate on WebEx Calling cloud but can't since the devices keep reverting back to the 8x8 prov server about 1-2 min after factory reset. 8x8 support not helpful since we have never been their customer.
Geovani
Hi there,
You have to open a case with Cisco to get the device removed from EDOS/CDA: https://mycase.cloudapps.cisco.com/swl?PNP
jk399
Many thanks!
cryy
Hello is this service still online / available?  Whenever I go to https://software.cisco.com/software/cda/home I receive a 400 Bad Request response.  I'm looking to get setup for the Cisco / Distributed Customer Role.  Thank you for your time in advance.
Geovani
Still available. Please try with an incognito window or clear your browser cache and try again. Its working ok for me.
