Introduction
This document explains how to configure the H.323 PRI and Gateway integration with the Cisco Unified Communications Manager (CUCM)10.x
Follow these steps to add H.323 gateway to CUCM:
Add a H.323 Gateway to CUCM 10.x
1: In CUCM 10.x Administration, Choose Device > Gateway.
2: Click the Add New button.
3. Select H323 Gateway for gateway type and
4. Click Next
5. On the Gateway configuration, enter
Device name: 10.1.1.5 (H.323 Gateway IP address)
Description:
Device pool: Sanjose / Default
Signaling port : 1720 by default
Leaver other parameters to Default
6. Click Save
7. Click Reset button and Check whether the IP Address of the Gateway appears
Configure the Voice Gateway for H.323 PRI
To Configure the Voice Gateway for MGCP PRI,
Open a telnet session to the router say at “Site-2” using putty
Router# configure terminal Router(config)# isdn switch-type primary-ni command Router(config)# network-clock-participate wic 0 Enter the controller configuration with ! # Controller t1 0/0/1 framing esf linecode b8zs pri-group timeslots 1-24 ! Type, # no shutdown Enter # Exit - to leave the controller configuration mode Enter interface configuration mode # interface fastethernet 0/0 H323-gateway voip bind srcaddr 10.1.1.5 Exit ! Enter a dial-peer and destination patter # dial-peer voice 1 voip # destination-pattern 144123456… Session target ipv4: 10.1.1.10 Exit ! Enter dial-peer voice pots to create dial-peer for PSTN # dial-peer voice 2 pots destination-pattern 9.T direct-inward-dial port 0/0/1:23 # Exit - to leave dial peer configuration mode # Exit – to leave configuration mode # write – to save router configuration |
Related Information
