Introduction
This document covers the configuration procedures on how to route calls based on Source IP address of SIP Invite on Cisco Unified Border Element (CUBE).
Problem Description
Requirement/ Issue:
Sometimes there is a requirement to filter and route the calls only based on Source IP address of the SIP Invite from the Service Provider network.
Sample call flow and configuration example:
Sample configuration to test and route calls based on Source IP address of SIP Invite.
IP Phone A --> CUCM --> SIP --> CUBE(SBC) ---> SIP ---> CME ---> IP Phone B
Sample Test Configuration:
IP phone A (2125553000) calls IP phone B (4088536000)
Cisco Unified Communications Manager (CUCM) 200.1.1.70
CUBE (SBC) 200.1.1.3
CME 200.1.1.1
Solution
Here is the solution with the configuration commands to filter and route the calls from VOIP Network based on Source IP Address on CUBE.
Sample Configuration
Restriction of Incoming calls through CUBE can be implemented using the Voice Source Group and Access-list
Following command needs to be issued on the Gateway:
IPIPGW-11#sh run
Building configuration...
Current configuration : 4693 bytes
! Last configuration change at 16:35:28 PST Tue Dec 6 2012
! NVRAM config last updated at 16:35:28 PST Tue Fec 6 2012
version 12.4
hostname IPIPGW-11
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
localhost dns:verizon.net
voice source-group test
! --- Create the Voice Source Group
access-list 1
! --- Access list that has IP address of the Origination end point - Source IP Address from CUCM
translation-profile incoming add111
! --- Translation profile to add prefix
voice translation-rule 1
! --- Translation rule to add prefix of 111
rule 1 /^4088536/ /1114088536/
voice translation-rule 2
! --- Translation rule to strip prefix of 111
rule 1 /^1114088536/ /4088536/
voice translation-profile add111
! --- Translation profile to add prefix to called number
translate called 1
voice translation-profile strip111
! --- Translation profile to strip prefix from called number
translate called 2
interface GigabitEthernet0/0
ip address 200.1.1.3 255.255.255.0
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 1.3.222.77 255.255.0.0
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 200.1.1.100
ip http server
access-list 1 permit 200.1.1.70
! --- Access list to permit the source IP Address of originating end point ie from Cisco Unified Communications Manager (CUCM).
dial-peer voice 2 voip
destination-pattern 212555....
session protocol sipv2
session target ipv4:200.1.1.70
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 4 voip
translation-profile outgoing strip111
destination-pattern 1114088536...
! --- Destination-pattern MUST be prefixed string
session target ipv4:200.1.1.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
line con 0
exec-timeout 0 0
privilege level 15
line aux 0
line vty 0 4
password cisco
scheduler allocate 20000 1000
ntp master 1
end
Debugs turned on for the IOS SBC
IPIPGW-11#sh deb
voip translation-rule
voip translation debugging is on (Filter is OFF)
voip source-group:
voip source-group debugging is on
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled (filter is OFF)
Related Information
Sarg .
Level 3
Level 3
Nice work. I enjoyed reading it.
Thai Dang
I don't think this is the complete example.  There is no dial-peer to prefix the called number with 111 from caller with source IP address call match.
