mohitgrover89@live.com
Community Member
First we've to understand Cisco IP Phone Registration & Boot UP Sequence>
Phone Registration Process
Step 1: Phone Loads Software (Image) and Starts the Configuration Process
Step 2a: Phone Sends DHCP Request
Step 2b: DHCP Server Sends DHCP Response
Step 3a: Phone Sends TFTP Request for a Configuration File
Step 3b: TFTP Server Sends the Default Configuration File
Step 4a: TFTP Server Sends the Specific Configuration File of the Phone
Step 4b: Phone Registration Finishes
FIRST UNDERSTAND THE BOOTUP PROCESS, START TROUBLESHOOTING ACCORDING:
General Troubleshooting Sequence:
  • Disable DHCP and DNS to Test a Phone
  • Check for the Incorrect MAC Address on the Phone Label
  • Cisco CallManager and TFTP Services Do Not Run
  • Delete and Recreate a Phone
  • Understand a Network Trace File
  • Use Performance Monitor to Analyze Phone Activity
  • Manually Configure the IP Parameters on a 12 SP+ or 30      VIP Phone
  • Add Phones to Cisco CallManager
  • Enable, Configure, and Disable Auto−Registration
  • Manual Registration (Add an IP Phone Manually) etc....
THESE ISSUES COULD BE THERE:
  1. IP Phone Registration Toggles between Primary and      Secondary CallManagers.
  2. Registration Rejected
  3. Cisco IP Phones Not Registered But seems to be working      fine.
  4. Cisco IP Phones Take Too Long to Register.
  5. Cisco IP Phone Always Get Registered to the Publisher      Server.
  6. Get "version error" on the Cisco IP Phone      screen When Try to Register.
  7. Cisco phones causing excessive DHCP requests.
Diagram/Flowchart representing, CISCO IP Phone Boot UP Process:
[DOWNLOAD THE ATTACHED PNG FILE @ LAST]
Step 1: Phone Loads Software (Image) and Starts the Configuration Process:
During this step, these issues could be there,
* Registration with a Cisco CallManager server is successful only when the server adds the phone or when the server has Auto−Registration enabled. (The default for Auto−Registration is disabled.)
* Note: If the phone LCD screen does not light up, you could have a faulty phone. The phone also could be
faulty if the message the phone displays never changes after you plug in the phone. Contact Cisco Technical
Support to request a replacement if your phone is under warranty.
* If your phones do not use DHCP, see the Step 3a: Phone Sends TFTP Request for a Configuration File section
of this document.
Step 2a: Phone Sends DHCP Request:
For Cisco 7940 and 7960: (to manually enable the DHCP Parameter on the phone itself):
Complete these steps on the Cisco 7940 and 7960:
1. Choose Settings.
2. Choose 3 (Network).
Scroll down to the DHCP Enabled parameter.
The selection must be Yes.
__________
Complete these steps on the Cisco 7910:
1. Choose Settings.
2. Choose 6 (Network).
3. Scroll down to the DHCP Enabled parameter.
__________
Cisco 12 SP+ and 30 VIP
Complete these steps on the Cisco 12 SP+ and 30 VIP:
1. Enter **#.
2. Enter 1.
3. Set all parameters to zero (0).
Note:
Cisco 7910G supports only 10 MB speed, but 7910G+SW supports 10/100. If you have a 7910G, be sure to set the switch port that connects to the phone to 10 MB or Auto.
Any IP parameters that you have hard coded on the phones override the parameters that the DHCP server provides. In particular, the Alternate TFTP Server option overrides the TFTP server IP address that the DHCP provides. For information on how to reset your phone configuration to the original
factory defaults, refer to either of these documents:
¨ Resetting 7900 Series IP Phones to Factory Defaults
Step 2b: DHCP Server Sends DHCP Response:
The DHCP response contains the phone IP address and the IP address of the TFTP server (which is usually a
Cisco CallManager server). The response can also contain any of or all these common options:
· IP address of the default router (gateway)
· IP address of the Domain Name System (DNS) server
· Domain name
includes option 150 for the TFTP server.
Step 3a: Phone Sends TFTP Request for a Configuration File:
  • The phone requests a specific configuration file. The      name for this file is SEPMAC−Address.cnf. For
example, the file name for a phone with the MAC address 0030.94C2.D5CA is SEP003094C2D5CA.cnf. If
the file exists on the Cisco CallManager server, see the Step 4a: TFTP Server Sends the Specific
Configuration File of the Phone section of this document.
  • If the phone is not in the Cisco CallManager database,      the request for the specific configuration file results in
a TFTP File Not Found response from the TFTP server. The phone then requests the file with the name
SEPDEFAULT.cnf. If you have configured the Cisco CallManager server for Auto−Registration, this file
exists and the server sends it to the phone. See the Step 3b: TFTP Server Sends the Default Configuration File
Otherwise, the TFTP server of the Cisco CallManager server sends another File Not Found TFTP
response. At this point, the phone restarts the configuration process.
Step 3b: TFTP Server Sends the Default Configuration File:
Note: This step only occurs if you have enabled Auto−Registration and the phone has not already registered
with the Cisco CallManager server.
If you have configured the Cisco CallManager server for Auto−Registration, it sends the SEPDEFAULT.cnf
file in response to the phone request. After the Cisco CallManager server database adds a phone by
Auto−Registration, the phone has a SEPMAC−Address.cnf file. It does not reference the SEPDEFAULT.cnf
again.
Step 4a: TFTP Server Sends the Specific Configuration File of the Phone:
Note: This step only takes place if the phone creation occurred on the Cisco CallManager server.
The configuration file contains several parameters for the phone. These include the device pool, the Cisco
CallManager servers to use, configured speed dials, and other parameters. In general, any time you make a
change in Cisco CallManager that requires the phone (device) to be reset, you have made a change to the
phone configuration file.
Step 4b: Phone Registration Finishes:
The Cisco CallManager server sends the phone additional configuration elements during the final phases of
the registration process.
In general, the registration process must complete successfully if the process goes this far.
To learn what takes place at this point, you need to set up a network analyzer to capture the IP packets that the phone sends to and receives from the server.
FACTS:
7961G Phone does not Register until it is Configured as a 7961>
IP phones CP−7961 and CP−7961G are basically the same platform. The G stands for global use that supports all languages.
So when you add a 7961G phone, you should add it as a regular 7961 phone. CP−7961G−GE is another IP phone with two gigabit Ethernet ports (10/100/1000).
If IP phone 7961G is added as 7961G−GE, it does not register with Cisco CallManager.
TASKS TO PERFORM:
Use Network Monitor to Analyze Phone Activity
By default, Cisco phones are DHCP−enabled. If you do not use DHCP, you need to disable DHCP on the phone and manually assign the phone an IP address. In order to disable DHCP on a phone, use the phone keypad to program the phone IP address and other network addresses.
Note: If you have your Cisco CallManager servers set up in a cluster, every server has the configuration files
for every phone that is in the Publisher database. Therefore, any Cisco CallManager server can serve as a
TFTP server for the phones. The device pools to which you have assigned the phones determine the server
with which the phones register. A phone can obtain the configuration file from a different server than the
server with which the phone registers.
Mohit Grover
Not applicable
Nice sir g
Not applicable
thank you so much! god bless!
Vinod Patil
Level 5
Level 5
Thanks, it is informative 🙂
Hello Mohit,
Nice explanation. Can you please tell me ip phone registration process in terms of SCCP and SIP protocol. What is the difference between those two protocols in-terms of registration perspective
Mohit Grover
Level 2
Level 2
chridiaz
I'm having issues registering a phone. This is a lab environment. If I connect the ip phone to the wall port it automatically registers to cucm via dhcp. I took a switch and connected to the port the phone was connected to. The phone gets power and the switch sees the phone but the phone is not registering. Any idea what can happening here? No security is configured on the switch.
Mohit Grover
Level 2
Level 2
Did you configure VLAN on the Switch/Module ?
Is the phone getting IP address from DHCP ?
On which device DHCP is configured ?
Clear the status messages, reset the endpoint & verify the status messages output.
What do you see on the Phone display ?
chridiaz
Mohit,
I did configure vlan as access mode. When I plug the phone directly into the wall port it receives an ip from dhcp, keep in mind since this is a corporate network I do not have access to configure the dhcp. However, when I plug the switch to the wall port, then the phone to the switch is not getting an ip. I did reset endpoint and the phone just stays in configuring ip mode. I'm wondering if I'm missing a command on the switch. I would appreciate any help.
ra 011
Level 3
Level 3
i have an issue
i have cucm pub and sub and tftp is the pub and 1st server in cm group is the sub and phones cannot register with subscriber it registers only with publisher
it gives error if i force it to register with sub says " registration rejected : security error "
sreeharikt
Frequent Visitor
Frequent Visitor
If the IP Phone has never been entered into the CallManager database via CallManager Administration, CallManager does not allow that phone to register unless auto-registration is enabled. Auto-registration does not work unless it has available directory numbers to provide the registering IP Phone a DN. If the IP Phone is not configured in CallManager Administration and auto-registration is not enabled or CallManager has run out of DNs, the phone displays "Registration Rejected."
In some cases, the phone might be having old residual security config that is no longer needed, in such case you need to factory reset.
ra 011
Level 3
Level 3
the phone is already  registered well with cucm pub but cannot register with sub and i have tried resetting the phone but same issue does i need to upload certificate from pub to sub ?
chadrife1
Hi and thanks for the sequence.  Is this still valid with time elapsed?   Running CE 10.5
My issue is that the phones register however two of them when attempting to call out go back to a registering mode.
DS3203
Community Member
Also can use this tool which helps in fetching the IP address and registration of phones easily from the CUCM.
https://www.networkclan.com/tools/voicetools/
apurvasaxena20
Community Member
hi....
You have explained the process well...
Could you please also suggest in the situation below:
I have a cisco IP Phone which gets unregistered frequently and sometimes do not get IPv4 add on DHCP also i tried to give static IPv4 add but always it gets registered for some time but gets unregistered again.
However if i connect the same LAN to the desktop there is no issue and the desktop gets IPv4 add and works fine.
How to get sure that its a LAN issue as i have changed the IP Phone device thrice. IP phone is connected to PoE.
Can the console logs be helpful? How to check the PoE power received by the device?
This is surely the LAN issue as the same device is working fine at other location but how can i give proof for it?
Also there is separate voice and data vlan in our LAN .
KINDLY HELP ON THE ABOVE ISSUE.....
