cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Keith Lunn on 19-05-2010 07:41:16 PM
CUCM 6.13
Does anyone know what security role must be granted to an App UID in order to query the RIS port?
I have a program that does an AXL query first (that works OK) and then has to do a RIS port request to:
[url=https://<publisher>:8443/realtimeservice/services/RisPort]https://<publisher>:8443/realtimeservice/services/RisPort
The App ID has the assigned role of "Standard AXL API Access" but it appears that it needs an additonal role to use the RIS port?
Thanks!
Subject: RE: What Security Role is Required for RIS Port?
Replied by: David Staudt on 19-05-2010 09:20:53 PM
Pls see this thread:
http://developer.cisco.com/web/axl/forums/-/message_boards/message/1481048?_19_redirect=/web/axl/forums/-/message_boards/search%3F_19_redirect%3D%252Fweb%252Faxl%252Fforums%26_19_breadcrumbsCategoryId%3D0%26_19_searchCategoryIds%3D0%26_19_keywords%3D...
Replied by: Keith Lunn on 19-05-2010 10:20:40 PM
Hi David - How goes! Thanks for the resonce. I tried that link and I got:
The requested resource was not found
However, with trail-and-error I have discovered that my app uid will work when it is in a group that has the following roles assigned:
Standard CCM Admin Users
Replied by: Keith Lunn on 19-05-2010 10:26:49 PM
Davud,
I tried to manual copy-n-paste the link into my browser and it worked ok. Yes, according to Stephan's findings - his answer correlates with mine - they key was "Standard CCM Admin Users" role. - Go figure!
I was trying Standard SERVICEABILITY READ ONLY and others..........I was off in the wrong direction and just for giggles decided to try CCM Admin Users as I have another uid that works ok with RIS - but it also has a ton of other roles configured - so I was trying to figure out the minimum config.
Thanks!
Keith
Ravi Shekhar
I was able to figure out the roles required for the AXL and risport:
for AXL you need: Standard AXL API and ccm standard Admin user
For RIS you would need the above two and standard serviceability role for the
