Cisco SX20 camera moving left right and shaking continuously.  We have factory reset the devices still it is a same problem. Even change the camera of working devices with issue devices still the problem.Now the software version of the device is  6.0
4 Comments
Dennis Mink
Raise a tac case and have it replaced
Michael Rubin
Down grade the software and upgrade again, connect the camera using known working wires and test.  The new wires should be used during upgrade and downgrade process.
Michael Rubin
Try adding or swapping the power supply to the camera.
PJMack
Level 7
Level 7
That is likely to be a hardware problem - I agree with the suggestion to open a TAC case.
