audacity help needed for cce/cvp audio
janinegraves
I'm trying to export audio recordings from audacity to use with CVP.  I hear silence when I call into them.
I recorded as 8000khz, 16-bit PCM (also tried 32bit float), Mono.
Export:  Save as type: Other uncompressed
Header: WAVEX (Microsoft) - I'd been told to use WAV (Microsoft) but that doesn't appear in the list.
(Screenshots attached online)
Encoding: U-law
I also tried saving as WAV (Nist) - no luck
I used this link recently and it worked for me. 8000Khz, 8 bit mono.
https://netcraftsmen.com/uc-toolkit-using-audacity-to-create-and-edit-cisco-uccx-prompts/
Thanks Elliot - seems like they simplified the process. It worked for me, many thanks!
