basic tcl and wav files required in VG for a stanalone cvp architecture
hy all
I am very new to this field and still learning can someone help me gain knowledge on this subject my question is
What are the files needed in VG for supporting a standalone CVP architecture  ?   (in specific the VXML,tcl and wav files ??
What are the use of the following services run in an ICM router ?
  rtsvr, dbagent, testsync, router, ccagent, mdsproc
What are the use of the following services run in an ICM logger ?
  configlogger, csfs, listlogger, recovery, replication
geoff
Level 10
Level 10
A stand-alone CVP VXML solution does not need ICM at all. You simply set up the services on the gateway
service CVPSelfService flash:CVPSelfServiceBootstrap.vxml
service helloworld flash:CVPSelfService.tcl
  param CVPSelfService-port 7000
  param CVPSelfService-app HelloWorld             <<<<<<<< whatever the VXML app is called
  paramspace english location flash
  param CVPPrimaryVXMLServer 164.103.128.20 <<<<<<<< primary VXML server
  param CVPBackupVXMLServer 172.20.142.20   <<<<<<<< backup VXML server
I usually also install
  service cvperror flash:cvperror.tcl
  service ringtone flash:ringtone.tcl
as well.
Geoff
