Hello all,
We have encountered applications running on 11.6 that are using an audio element to set session values, and then they are marked as 'skipped' in call studio.
The call servers are no honoring the 'skipped' tags it appears, as the session values are still being set according to the element configuration.
The applications weren't coded with an application modifier element to set session values, which is interesting, but this skipped behavior is even more strange as 'it shouldn't work'.
Has anyone encountered this behavior?
Solved! Go to Solution.
