12-13-2011 11:14 AM - edited 03-14-2019 09:02 AM
I have program an outbound IVR based campaign on a CCX 8.5. The script, application, trigger, call control group (outbound) and SIP gateway are configured.
If I dial the trigger from a ip phone, the message is reproduced. So I can be sure the appliccation is working.
When I enable the campaign, I recieve the call (in all phone numbers of the contact list). But the message is not reproduced, only a part of the CUCM annunciator ("Your call cannot be...."). After 34 seconds the call is dropped.
Can anyone please help me?
Edgar.:
12-13-2011 01:28 PM
Send me your configuration in screen shots and the SIP gateway config.
12-13-2011 01:29 PM
Send me the screen shots of your configuration and the SIP GW config
12-14-2011 10:52 AM
12-14-2011 10:57 AM
Is it one way audio or no way audio
David Constantino | Sr. Architect, Unified Collaboration | Insight | www.insight.com
t. 480.333.3450 c. 704.996.0390 david.constantino@insight.com
The information contained in this message and any attachment may contain privileged or confidential information protected from disclosure. If you are not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any review, dissemination, distribution or copying of this information is strictly prohibited. If you have received this transmission in error, please notify the sender immediately by replying to this message and destroying the original and all copies. Thank you.
12-14-2011 12:58 PM
It's no way audio.
03-12-2013 05:56 PM
Hi.
I have the same problem..
Somebody found the solution?
Thanks for the help...
