CCX Call Recording and Silent Monitoring/Barge
James Hawkins
Level 8
Level 8
I am currently planning a CCX deployment which will use always on active recording using a third party recording product called Red Box Recorders. This product uses the BiB in the phone to fork a stream to the Red Box Recorder server.
My query is if this recording is configured does that mean that the built-in CCX features for silent monitoring and barge will be disabled. My guess is yes as the also use the BiB but would like to know if this is correct.
Graham Old
Level 7
Level 7
The BiB forks the audio streams to a recorder and can also fork a separate stream for silent monitoring.
You will be able to use Finesse silent monitoring and barge along with your Red Box recorder.
Graham
