ā10-15-2010 02:22 AM - edited ā03-14-2019 06:41 AM
Hi Everebody
I am installing the Unified CCX - but I am CRS
Administration an CRS
Engine Process are always going to
DISABLE mode. I put it back to enable an restar CIsci CRS Node Manger Servive , but after 3 or 4 min its gos to disbale again
Does any body now how can I fix this issue
Other question concerning the "
CRS Admin Utily" - What is the user name and password ?
CRS Administration an CRS Engine Process are always going to Disable
ā10-15-2010 06:34 AM
Was IP address of the server changed after the UCCX was installed ?
In regards to the CRS admin utility login question - the credentials you use is the administrator account (Administrator).
This is the account you used for installation and generally when you login into the box
Hope this helps
Anuj
ā10-15-2010 08:56 AM
Thanks for your feed back
Was IP address of the server changed after the UCCX was installed ? - No its the same
This is the account you used for installation and generally when you login into the box - I am using the same credenciat but are not loggin , I receive a message "Administrator logon failed.Please ensure proper passwor is entered
Hope this helps
Anuj
ā10-15-2010 09:00 AM
I guess MIVR trace analysis and peek to the server will be required to better understand the issue , you know were I am going with this
Anuj
ā10-15-2010 09:26 AM
ā10-20-2010 11:17 AM
Hi Team .
Any help ?
ā10-20-2010 05:42 PM
As advised earlier in this regard I will suggest you to open a TAC case
Anuj
