Extracting values from Form element in CVP
dipmehta33
Hi Team,
I am trying to integrate CVP with speech recognition engine and looking for a way to store the utterance in the element data and store those values in database. The intention is to know what customers are speaking.
In the logs, i could see that the values are stored in the Form element - utterance and nbestutterance1 but how do i extract them and store in either a local varaible or element data.
Form_01,interaction,utterance,i would like to know the status of my application
Form_01,data,nbestUtterance1,i would like to know the status of my application
When you see 'data' in the column just after the element name in the Activity Log, it means that it's ElementData with that name and that value: Form_01,data,nbestUtterance1,i would like to know the status of my application
Studio doesn't display ALL element data in the Substitution Tag Builder! But you can still access it by keying it in from your keyboard.
In Studio,
1.Go into the Substitution  Tag Builder  {},
2.Select the Element Data tab
3. Choose the Element: Form_01
4. In the Variable Name field, use your keyboard to key in the variable name nbestUtterance1 (case sensitive! and remember the 1 at the end.
5. Then press Add Tag:    {Data.Element.Form_01.nbestUtterance1}
Hope that helps!
5 Replies 5
david.macias
This doesn't answer your question, but I would personally not do this from the IVR, but pull it from either the CVP logs or the Nuance logs. This way you have one less dependency in your IVR and you're able to do all sort of analytics on the logs offline.
david
Thanks David. It is easier for technical folks to extract the values from logs, however business guys do want an easier way to keep track of things. I was referring to Janine'solution on the  thread mentioned below and i am able to extract the value of intent by storing it in Field Slot and extracting the value in element data by value.
I would like to take the same approach if available to extract the other value.
https://devnetsupport.cisco.com/hc/en-us/articles/115011103207-Form-Element-Nuance-Get-returned-value
posting it in devnet to gain additional visibility
In Studio,
Hope that helps!
Thank you very much @janinegraves . It works :)
In Studio,
Hope that helps!
