Finesse layout not populated when using Connect Step
LabanM
I'm working on a script that would send a call to an agent regardless of finesse state. I have it working well using the connect step, however the finesse layout does not get populated with Enterprise data that is set from a database dip. Is this normal functionality or is there another step I'm missing?
I am setting the resource from database dip as well not from CSQ.
I should mention that the finesse layout is populated with the correct data when the call is sent to an agent using the Select Resource Step.
Running UCCX 10.6.1
Anthony Holloway
Hold up. You're using the Connect step, without first using the Select Resource step?  I'm surprised it even did anything, and bravo to you for attempting to use it without reading the documentation.  You're a real life cowboy, and I like it!
What you are probably looking to do is, use the Select Resource step, but switch it to Agent Based routing instead.  I'm positive your Finesse layout will now work.
Anthony Holloway
I read the documentation after posting and tried again. It worked after nesting in the Select Resource step using the mentioned agent based routing method but only when agent was in a Ready state, doesn't look like sending a call to an agent when in not ready state is possible with showing the layout. Going to have to rethink this.
Thanks for the input.
