Help in Creating script.
Candreas2
I need some help, how to create a scenerio when user enter 1, it will take him to English and 2 to Spanish. I can assume this could be simple task. However, I am new to scripting. Thanks. Chuck
oabulaban
what's your system? ucce or uccx?
Sent from Cisco Technical Support Android App
Hi Charles,
What you will need is called the Menu step. The Menu step is designed to allow a caller to make a choice, later base on tha choice you can transfer the call to English or Spanish so just using the Script Editor add a Menu step.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
