help with creating a simple queue script with voice messages if busy
baselzind
Level 6
Level 6
this is my first time creating a script, i need to create a script where it is a queue for agents and if the agents are busy
multiple voice messages will play until an agent answers it is like the following
the caller enters the queue>1-if busy play "agents are busy">2-if still busy play promotion voice message>3-if still busy play please wait for voice message>4-if still busy play a second voice promotion
my question do i merge all messages 1,2,3,4 into one voice message?or i make 4 prompts in the script?
and most importantly will the below script work for this scenario? i would just right click "select resources" and select my csq
15 Replies 15
No, you would choose CSQ, as that would hold the value of either CSQ1 or CS2, depending on the press. Likewise, your Play Prompt references will reference a common name, e.g., welcome or please_hold, while the actual value would be variable depending on the press. Look more closely at what I've done for the CSQ, because I think you're glossing over how variables work.
