02-03-2017 06:33 AM - edited 03-15-2019 06:27 AM
Hi All,
Hope you all are doing well, Please suggest me how to create dial-peer on voice gateway to dial US country. I have PSTN lines configured on voice Gateway.
Example no:
Dial no: +1480 xxxxxxx
Thank you,
Arjun Kamble
Solved! Go to Solution.
02-13-2017 05:51 AM
Here is an example for outbound POTS dial peer:
dial-peer voice 9100 pots
trunkgroup PRI, or use port i.e. 0/0/0:23
description PSTN LD LD - Outbound
destination-pattern 91[2-9]..[2-9]...... <---- assuming you want to send 9 as prefix from CUCM, otherwise remove the leading 9
forward-digits 11
As to Route pattern, create one as 91[2-9]XX[2-9]XXXXXX and point to Route List/Route Group/Gateway or Trunk for this gateway.
02-04-2017 08:23 AM
Wrong sub forum, as this is for Contact Center questions. The IP Telephony sub forum might be a better spot.
02-13-2017 05:04 AM
Thank you Anthony for writing me, There is no Dial peer information in given link. Could you please provide me the new or Dial-peer contained links.
Thank you,
Arjun Kamble
02-05-2017 10:15 AM
What country is the call from, US or somewhere else?
What trunk type is it pointing to? SIP vs. POTS?
US national patterns can be summarized as 1[2-9]..[2-9]...... so you can use that as your destination-pattern or e164 maps depending on trunk type and preference.
02-13-2017 02:28 AM
Thank you Chris,
We are using here POTS not SIP trunk............... and destination no starts with 148xxxxxxxxx. I need to create dial-peer and route patterns.
Please help on this...........
Thank you,
Arjun Kamble
02-13-2017 05:51 AM
forward-digits 11
