how to use fetch audio vxml property for the requirement in cvp.
sandeep2018
I have to implement the below requirements.
1.use the fetch audio vxml property to play the percolator noise wav file.
2.set the  fetchTimeout  vxml  property to (TBD) so that the gateway doesnt timeout  while the percolator  noise is playing  while
waiting for you  to send the next page.
Anyone please help me how to use fetch audio property to get my requirement done.
janinegraves
put them in the VoiceXML Property portion of the Settings tab of the
voice element immediately prior to the slow back-end interaction.
janinegraves
sreekanth47
Level 4
Level 4
You can use VProperty.AUDIO_TO_PLAY_WHILE_FETCH and add this to form.
