08-31-2010 12:43 AM - edited 03-14-2019 06:24 AM
I can using "\*" as valid input.
However, how to using "#" as valid input with Form Element?
Please guide me to solve this problem.......
P.S.
CVP 7.0.2
ICM 7.5
Mark
Solved! Go to Solution.
08-31-2010 08:43 AM
You need to set a VXML property to redefine the termination character (termchar) which is, by default, the pound sign. Typically you do this on the application as a whole, although you can be more specific and do it on the element and redefine it on the next element.
You can set it to nothing - use space in quotes.
Geoff
08-31-2010 08:43 AM
Geoff
