HTTP Post using Cisco WorkFlow UCCE 11.5(1)
Swaminathan N
I am trying to use the Cisco Workfllow to make HTTP post request to local machine(In which Finesse agent desktop is running) during answer call . But the request is not triggered.
Below is the Workflow configuration.
Type- HTTP Request
Handled By - Other
Method - Post
Location - Other
Content Type- application/json
URL - http://localhost:9090/testing?Num=123
Kindly advice
Swamiathan.N
dekwan
Hi Swaminathan,
The Finesse workflow HTTP request is actually made on the Finesse server itself. If you want to trigger something on the client machine, you have to create a custom gadget that calls the http request directly. You can modify the WorkflowScreenPopSampleGadget to do this.
Thanx,
Denise
