03-21-2011 10:36 AM - edited 03-14-2019 07:37 AM
Hello
I have an issue where when a UCCX agent misses a call, they automatically go to a not ready state. I just saw a post where they talk about changing a service paramater on ring no answer to keep the state "ready". Is that the fix for that or is there anything else that should be done?
thanks
Solved! Go to Solution.
03-21-2011 02:06 PM
Yes.
Try both , see how can they work and choose but both can work .
Amer
03-21-2011 01:23 PM
Change the below and test.
\program files\wfavvid\SubsystemRmCm.properties
Edit that file and change com.cisco.wf.subsystems.rmcm.agentUnavailRNA=true
to False
Amer
03-21-2011 02:03 PM
thanks
I also saw a post where they mentioned you could go into the UCCX admin page and go to system parameters, application parameters, system state after ring no answer and set it to ready. Will that also work or just work for some circumstances?
thanks
03-21-2011 02:06 PM
Yes.
Amer
03-21-2011 03:15 PM
