Issue with VXML application
himanshu87
I am facing some issue with VXML application. I am using gns3 and have tried multiple router images.
If i am referencing vxml script int the ICM script the gateway goes into vm is not running will be unresponsive (status=1).
The call runs fine if i am using PM message in Run external script.
Can anyone help me in setting up a ingressvxml gateway in lab(gns3 or VMware). I am stuck at this point as i am not able to test any call studio scripts.
Thanksu
Himansh
16 Replies 16
Please ignore all the asterisks *** in previous email.
Hey Bill/ Janinegraves,
Thank you for taking the time and checking the issue.
My issue got resolve actually.
The issue was when I initially created the Application I used a different wav file and later I changed it. So after that I re-deploy my application and updated the changes in application Admin folder.
But what I found is post redeploying the application we have to move the newly deployed folder from "C:\Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime\AUDIUM_HOME" to the C:\Cisco\CVP\VXMLServer\applications and then we need to again update the app.
My issued got fixed by doing the above.
Thank you again for all your help.
Regards!!
Subh
Subh
