Max step counter - and how UCCX counts steps
kbenoit33
Greetings,
I'm curious, how does UCCX count steps?
Is every branch in an IF statement counted? What about annotate, labels, GOTOs? For example ..
(1) Label   S T A R T
(2)   IF (2==2) then
(3)     true
(4)        do this
(5)        do this
(6)        do this
(7)    False
(8)        do this
(9)        do this
(10)      do this
(11) Annotate /* the above IF statement only works on the 3rd Tuesday of months ending in r */
(12) GOTO   S T A R T
So, does every pass through the above example count as twelve steps? Regarding the IF statement - I'm thinking it only counts the steps the condition meets however, I could be wrong.
Thanks for your time and attention!
Keith
Gergely Szabo
each executed step counts, regardless of the structure or the number of steps in the script. So if you have a script consisting of two steps, for instance, a Play Prompt labelled as 'PROMPT' and the second step would be a Goto PROMPT and the global parameter of max steps is 100, then you would hear the prompt 50 times.
There might be exceptions to this rule, though, when forking/triggering applications.
G.
kbenoit33
Hi Gergely,
Thanks for the speedy reply!
Keith
