07-17-2011 11:45 PM - edited 03-14-2019 08:14 AM
I have a issue when I tried to purge the database,It has 55% an interogation of database work very slow.
My trouble is that I cannot delete information of database from db_cra from contact center aplication.
All the best,
Dan.
07-22-2011 03:01 PM
Dan,
Are you refering to the historical data purge or just the UCCX database in general? Can you also tell me whether you are running a MS SQL Express or MS SQL full version? There is a known issue with the historical tables not purging that I can point you to, please let me know what you are seeing and I will do my best to help you.
Robert W. Rogier
CSE -- TAC, UCC
07-24-2011 11:47 PM
Hello Robert,
Many thanks for reply, I would like to purge Historical data, the version of database is Microsoft SQL Enterprise Manager
Microsoft Corporation Version: 8.0, I opened the case at Cisco TAC but they told me that issue is because of NIC Timinig, in this
night I will desolve NIC Timinig and after that I will try again to purge data.I will send you the news.
All the best,
Dan.
08-02-2011 02:53 AM
Hello Robert,
I want to connect UCCX version 5.(0.2) trough fiber channel at external storage as SAN, what kind of HBA is support IPCC, if it is supported.
Many thanks for all your advices.
All the best,
Gudila Aurelian.
08-02-2011 08:38 AM
Dan,
As far as connecting a MCS server toi a SAN, this is not supported. You need to stick to the MCS servers and the built-in storage on them. If you wish to use a SAN you can upgrade to UCCX 8.5, migrate your servers to a UCS platform and then be able to use the SAN. Please let me know if you have any other questions on this. .
Robert W. Rogier
CSE - TAC, UCC
08-02-2011 11:33 PM
Hello Robert,
Thanks a lot for reply and advice, I will send you news about our progress .
Many thanks again,
Dan.
07-27-2011 12:23 PM
From server CLI, run:
osql -E -S .\CRSSQL
use db_cra
go
sp_spaceused
go
If you have large amount of "unused" space and limited "unallocated space", you are likely run into CSCtb21056, a Microsoft SQL server issue.
