Remote expert mobile installation 11.5.1
Dear All,
 We are trying to Install remote expert mobile single node deployment . Post deployment we have an issues for Integration .
I have done the setup.sh and post reboot  REAS & REMB and is running . please let me know what is the next step   and how to integrate with DX 80 as end point .Please  help me to achieve .
Thanks & Regards,
S. Ram
Ram.S
Sasikumar Divvela
you are trying to use DX80 as agent end point ?
Which deployment you are configuring the system ? PCCE/UCCX/UC only ?
In REAS web controller you need to do the required configuration based on the deployment . -- This you can follow the guide.
And there are some Video's available in cisco site, did you try referring those ?
Hi Sasi,
We have installed Single server deployment and post deployment REAS & REMB services are running .
When we are publishing the URL for agent console we are getting “There are no backend servers, your request can't be loadbalanced.  “
During the deployment we have given below information .Please advise cluster host name and host name  will be in same name or different .
Cluster hostname : remmobile.gov.com
Hostname : remmobile.gov.com
Server type : B ( Installed an REAS & REMB ) REAS node type : M ( Master )
Thanks & Regards,
S. Ram
Ram.S
Halo Rama,
You should use different host name between cluster and your server host name.
For ex : cluster hostname -> reas.cisco.com
hostname -> reas-a.cisco.com
Also make sure when you finish on setup.sh, you pass all configuration setup without any failed test.
Regard
Novriadi
