script rename problem.
zkalbiyev1985
Hello Frends.
I change the name of the script in scirpt in uccx, it does not work.We wanted to make a script change in uccx.We made some changes in the script and created an Applications list named AMw for testing.But it didn't work.Then we checked by renaming the currently running script, but it didn't work.
Does not work when renamed.We have made such changes before and it worked fine.
What could be the reason?
I'm not sure I follow, can you spell out the changes you made and what you were expecting to happen? If you rename a script, make sure that the application still references the right script, it should. If you add an application did you configure the trigger to go to the right application?
david
