Seeking Assistance with Monitoring UCCX Script in CheckMK
MikeHoliday
I'm in need of some assistance regarding monitoring a specific number through a script in CheckMK. I have a script that operates on a particular number, and I would like to implement monitoring for this number using two criteria.
Firstly, I would like to check if the number is reachable. Secondly, I want to monitor if the script is functioning properly. This could be achieved by setting a custom variable to a specific value. I intend to perform these checks at regular intervals, such as every few minutes.
My objective is to integrate this monitoring process with CheckMK. I wanted to inquire if there are any existing solutions or implementations for similar scenarios within the CheckMK ecosystem. Alternatively, I would appreciate guidance on whether it would be more appropriate to develop this monitoring script using UCCX or Python.
Any assistance or suggestions would be greatly appreciated.
Thank you,
So you can do SNMP monitoring (https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_0/maintain_and_operate/guide/UCCX_BK_UD831833_00_unified-contact-center-express-operations-11/UCCX_BK_UD831833_00_unified-contact-center-express-operations...) you'll have to figure out if you're able to filter on the script you want. What I think you're actually looking for is something more granular that actually traverses through the script. For this, we've done it with Twilio where we place a call every x minutes and record the interaction. If the interaction doesn't match our expectation, for example there's a long delay or the word "error" gets mentioned, then we send an email alert.
david
