06-05-2008 06:07 AM - edited 03-14-2019 02:20 AM
we are about to implement silent monitoring in our IPCC environment (CCM: 6.1, IPCC: 7.2) with CTIOS based desktop clients. Cisco provide 2 solution: one is CCM based the other is CTIOS based solution.
We were told that the CCM based is the better option and that the CTIOS option is based on an "OLD" architecture, which will maybe no more available in future IPCC releases, so the CCM based is the way to go.
I want an expert view on this matter as we would prefer the CTIOS based solution. will future IPCC release support the CTIOS based version?
THX
06-21-2008 03:04 PM
IPCCE 7.x SRND guide primarily talks about Silent Monitoring with CTI Toolkit Desktop and Supervisor. It gives a very good explanation on how it works, however it hardly touches CAD.
CAD also has monitoring and additonal recording services, however seeing a few remarks on CAD in SRND guide I see that it might be acting differently...
For example SRND states that with CAD only SPAN option exists when monitoring agent using Citrix to run CAD software...
Is there a document that describes how monitoring and recording works with CAD? What similarities does it share with CTI OS clients? Is there a concept of decoupling CAD application from Silent Monitoring Service which would then make it possible to run CAD in Citrix or Mobile agent option?
Thanks!
David
06-21-2008 07:15 PM
Contact Center Enterprise supports 3 monitoring methods: desktop, SPAN and UCM-based. All three are supported by CTI OS desktops as well as CAD desktops. CAD and CTI OS each have their own implementation of the first two methods.
Monitoring using one of the first two methods is initiated from the (CTI OS or CAD) supervisor desktop and the audio is intercepted by the (CTI OS or CAD) agent desktop when using the first method or by the (CTI OS or CAD) monitoring server when using SPAN monitoring; the audio is terminated at the (CTI OS or CAD) supervisor desktop (i.e. at the PC).
A monitoring session using the 3rd method is initiated from the (CTI OS or CAD) supervisor desktop in the same way as the first two methods, and the audio is sent by UCM to the supervisor IP Phone.
Which monitoring method is used depends on configuration and available monitoring servers.
For agent desktops running in Citrix any of these three methods can be used. In order to use the desktop method with Citrix, a CTI OS monitoring service needs to be installed on the PC connected to the phone (same PC as where the Citrix client runs). If this is not possible (e.g. when the PC is not a Windows machine, or when CAD is used), the UCM (preferred) or SPAN method must be used.
For a Mobile Agent only the SPAN method is available (desktop monitoring doesn't work as there is no IP Phone to intercept the traffic from; the UCM method doesn't work as there is no IP Phone to bridge the media streams).
Contact center Express only supports CAD-based desktop or SPAN-based monitoring. It does not support UCM-based monitoring.
Hope this answers most questions raised here. A white paper and presentation material on this topic will be posted on cisco.com within a few weeks.
Willem Evert, Cisco CCBU Product Management.
