String variable of Unicode characters problem
samhopealpha
Level 2
Level 2
Hi all
I define a variable named "vRemoteParty" ... with String type
in order to store the return value of "7748"
I got the following result via the UCCX debugger ...
Result: U"\u3737\u3834"
suppose it is result: 7748 ...
So. how can I convert this unicode character in UCCX script??
I tried the String.valueOf() but seems not working
Anyone could help
Sam
samhopealpha
Level 2
Level 2
I found that the problem only existed while connected to MySQL database
The STRING returns correctly if querying with Microsoft SQL.
Does it mean the UCCX does not support MySQL??
or there is any setting should be changed in MySQL or UCCX
Sam
jtp777001
I'm not sure if this is helpful but Unicode digits start at 30 for 0 and end at 39 for 9. Given that the Latin alphabet ends at 7A, there may only be support for two hex digits. That would make the output of \u3737\u3834 the number 7784. If the return value is always a number you may want to store it as an int.
Edit:
After looking at it more, the \uxxxx notation is for a char type literal.
