10-26-2006 11:20 AM - edited 03-14-2019 12:13 AM
Wondering if anyone is running System IPCC without any issues. We are running 7.1.2 and experiencing frequent opc crashes. We are considering re-deploying and not using System IPCC, but was wondering if anyone else was having isses with System IPCC. We have a TAC case open but trying to consider all the options so looking for some feedback
11-01-2006 11:19 AM
It looks more that the issue is related to a CPU leak in CCM. A network audit should be plan
11-02-2006 08:59 AM
It was an issue between CM and ICM and the call ids, dev came up with an ES that fixed it
11-03-2006 08:44 AM
Do you have a BUG ID or ES #?
