System IPCC Question
mw9714
Agent extensions are currently 5 digits. In the IPCC Web Administration, CallManager Connecivity, I see "CallManager Agent Extension Length" is set to 8. What effect if any does this have on operation?
I know you.
The impact is nothing as long as the extension length you specify is less than or equal to 8 digits long. If you try some 9 digit extension, it will spit cti errors.
I know you.
Yes you do. I guess I'll have to rate your post then.
What I saw in the installation and configuration guide didn't give much info other than what the default is.
Thanks!
Mike
