TTS Speed thru Say It Smart
GauravTMG1
Is there a way, we can reduce the speed of TTS while speaking numbers. For example, while speaking 123456789, there should be a certain seconds of delay between each digit.
david.macias
See other answer, for this particular scenario you want to use the <prosody rate> in your VXML app.
david
6 Replies 6
david.macias
david
I tried using prosody rate but it's not slowing the speed of TTS. Please advise if this is correct.
I got it! It's working now.
I just saw your picture, glad you figured it out!
david
Vendor specific - but it does work with Nuance TTS.
Geoff
I believe it's a standard, I've tested this with Nuance, LumenVox, and Polly.
