09-10-2019 06:38 PM
Hello guys,
I’m trying to install ICM (CCEInst iso) under windows 2016 server as recommended by Cisco matrix compatibility , but after install sql 2016 sever and try to install icm , I got SEVERE error , indicating that installation require Windows Server 2012 R2 ... should I install Cisco CCE under Windows 2012 R2 and then upgrade to Win Server 2016 ?
thank you guys in advance
Solved! Go to Solution.
09-10-2019 10:07 PM
The iso which you are using must be old. There is a new CCE iso made available to customer (around a month back) which supports 2016 OS. Please try to get the latest iso and try installation.
09-11-2019 06:27 AM
Sasikumar is correct, you need an updated ISO.
Here's something a little more specific...
09-10-2019 06:55 PM
You need install SQL 2017.
09-10-2019 07:04 PM
Hello Omar
I just updated it to SQL Server 2017 (after remove 2016 version ) and still requesting Windows 2012 R2 ...
09-10-2019 07:07 PM
09-11-2019 07:13 AM
09-10-2019 10:07 PM
09-11-2019 06:27 AM
09-11-2019 07:10 AM
Hello Guys,
you are correct , my ISO file don't allow installation under windows 2016 server, as I can't find the ISO file on CIsco website I decided to install UCCE ICM 12 under Windows Server 2012 R2 , I was able to install it correctly.
Thank you so much for your support
Leonardo
09-11-2019 07:15 AM
09-11-2019 07:26 AM - edited 09-11-2019 07:32 AM
If you're going to do an over-the-top upgrade of the OS and SQL, here's some specifics...
Here's a link to the Engineering Specials for 12: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/icm_enterprise/ucce_b_unified-contact-center-enterprise-engineering/ucce_b_unified-contact-center-enterprise-engineering_chapter_0101.html
Also, the new ISO should be available to you through the Product Upgrade Tool. If not, open a TAC case or contact your Cisco rep
09-11-2019 12:19 PM
