03-22-2021 06:15 PM
There is some guide or documentation where I can support or someone who can guide me in knowing the protocols or programming languages with which I can integrate a traditional ivr script to a general banking network for example to make a query or block a product.
that uccx version 12 can be integrated natively or on its own without depending on third-party applications or platforms, for example without web server between the uccx and the banking database.
03-23-2021 01:55 AM
Hey Y.
It all depends of what kind of integration your banking system has.
For one of my customer (also a bank) i use the MAKE REST Call step to integrate directly to they banking system. This is returning JSON that i then make my routing strategy from (if the customer has account (and have many ), apply for a loan etc.).
I make the call with a user pin and they number (in the body of my rest call) so I validate them to the banking system.
You can read more of the MAKE REST CALL step her
UCCX REST/JSON Post - Page 2 - Cisco Community
The rest step can alse return XML or what you want - depends of you service you are calling
You can also integrate directly thru SQL if that what you want instead.
For both of these you don't need a middleware server, both integrate directly from the UCCX server.
What kind of integration does your banking system has ?
Thomas
03-23-2021 03:34 PM
03-23-2021 02:03 AM
For the Database integration you need premium agents, and for using the MAKE REST CALL you only need an enhanced license
