05-25-2011 07:39 AM - edited 03-14-2019 07:58 AM
I need to create a script to connect to an enternal SQL server to write the post-call survey data. I created an ODBC connector to the external SQL server on the UCCX server (using SQL authentication). In the script, I put the DB Write step. However, I don't see the DB on the "Data source name". I checked the documentation but no detail about how to connect to external DB. Please help.
Solved! Go to Solution.
05-25-2011 08:25 AM
Did you create the datasource in the UCCX administration page? You need to create it in Subsystem>Database, the same as the ODBC.
Gabriel.
05-25-2011 08:25 AM
Gabriel.
05-25-2011 09:05 AM
Thanks Gabriel. It worked.
Another question:
After agent finsih the call with customer, we want the call to be transfered to the post-call survery application. Is there a way to accomplish this task without agent intervention. For example, can we re-function the answer/drop button on the Cisco Agent Desktop to actually transfer the call to the survey application. Thanks in advance.
05-25-2011 09:17 AM
Hmm I think you will need to workaround this, here are some links that may help you:
https://supportforums.cisco.com/message/3156116#3156116
Gabriel.
05-25-2011 09:24 AM
Thanks for the direction. I will dig into that.
