UCCX compatibility with MCS-7816-I5-IPC1
youssef.erraki
Hey every one
I would know if UCCX version 8.5 can be installed on UCS 7800 (MCS-7816-I5-IPC1), because when i try to do the installation procedure it show me error that the hardware used is not supported.
NB : I alredy install CUCM 8.5 on the same server and it work great.
Best Regards
youssef.erraki
I would know if I could installed on other server not Cisco??
Below is list of support hardware .  If you will install UCCX on unsupported hardware then you will lose TAC support . If you are not able to install UCCX 8.5 on 7816 then check if hard drive is in good condition . You can try to install from some other DVD.
MCS-7816-I3-CCX1
MCS-7816-I4-CCX1
MCS-7816-I5-CCX1
MCS-7825-I3-CCX1
MCS-7825-I4-CCX1
MCS-7825-I4-K9-CXA1
MCS-7825-I5-CCX1
MCS-7835-I2-CCX15, 7
MCS-7835-I2-CCX27
MCS-7835-I3-CCX1
MCS-7845-I2-CCX16, 7
MCS-7845-I2-CCX27
MCS-7845-I3-CCX1
MCS-7816-H3-CCX1
MCS-7825-H3-CCX1
MCS-7825-H4-CCX1
MCS-7835-H2-CCX15, 7
MCS-7835-H2-CCX27
MCS-7845-H2-CCX16, 7
MCS-7845-H2-CCX27
Ravi
