UCCX - Forwarding call to a specific agent - HELP!!!!!
brunofalco
Good afternoon,
I am implementing an IVR, and I am with the following problem.
If I get an external call to extension 5000, it should be directed to the agent 1, if I receive an external call to extension 5001, it should be directed to extension 5001.
I would know if there is a way to configure the script so that it forward the call to a specific agent only, and not to a queue.
Bruno
Once the condition is met , setup select resource setup to select the exact resource instead of selecting from CSQ
Make routing target type as Resource and set up resource target.
Mohamed
Mohamed
Hi Mohamed,
Help me a little more, please.
I did not work that way more.
How I need to create variables ??
For example, the agent who receives the call will be "ipelite2".
How do I identify it in the variables? I use Type "User"?
Bruno
Yes you are right
Name - username / agent id
Type - User
Value - null ( default)
In the select resource step -> Resource Target and Resource selected will be agent id.
Please try and let me know
Mohamed
Hi Mohamed,
Sorry for delay,
You're right.
Thanks for your help!!!!
Bruno
