UCCX Script for connecting to Web Service using https
h-vijay_singh
I want to connect to web service (Oracle CRM on Demand, it is a secured layer i.e https://) using UCCX script. I tried using URL document, it failed. Is anyone has done this scenario?. If you can provide brief about the steps I can try.
Rgds
Vijay
lohjintiam
Level 4
Level 4
My understanding is UCCX (IP-IVR) can only do ODBC integration while CVP does both ODBC and Web Service integration.
Thanks!
-JT-
Anthony Holloway
I have deployed this in the past, and it works flawlessly.
See these posts as reference:
https://supportforums.cisco.com/message/3072941#3072941
https://supportforums.cisco.com/message/3043225
Give it a shot, then post back your troubles.  I'll see if I can help.  Good luck.
