Using Rest_Client element for POST API
Mohamed Youssef
Frequent Visitor
Frequent Visitor
Dears,
I am trying to trigger POST API using the call studio Rest_Client element but It's not working. However, I am using the same setting in POSTMAN and Its working fine !!
UCCE , CVP , call studio versions : 11.5
Simple IVR application:
Welcome message > Menue > press 1 to trigger the POST API>  Rest_Client > End
Here are the Rest_Client element settings:
Endpoint:https://<FQDN>//unifiedconfig/config/campaign/5004/import
HTTP Method: POST
Parameters:
Ignore Certificate Validation: true
Require HTTP auth: true
Username: username@FQDN
PW: password
Headers:
Body:
     <import>
          <overwriteData>true</overwriteData>
              <fileContent>
                  <![CDATA[
                  AccountNumber,FirstName,LastName,Phone01
                  6782,Mohamed,Youssef,72072415
                  </fileContent>
                   <delimiter>,</delimiter>
                    </import>
Use Proxy: false
Connection Timeut:3000
Read Timeout: 5000
For the CVP logs: Attached is the activity logs. there are no error logs been generated!
Hi Mohamed
You will need to write the response body to the logs.  On the general tab of your REST_Client element go to the add to log section. Add in any name such as log,.response , then {Data.Element.Rest_Client.response_body} in the value and create after.
This will let you know if you are actually getting a response or not and you can continue troubleshooting from there
