11-10-2012 11:57 AM - edited 03-14-2019 10:49 AM
We are planning to deploy UCCX 9 in our environment, just wondering if we do order the UCCX 9 premium version, do we still need to implement IP IVR?
If so, is that require additional licenses?
Solved! Go to Solution.
11-10-2012 02:04 PM
IP IVR does not include the RmCm subsystem and therefor has no ACD functionality (i.e. no Skills/CSQs/Agents). It's used primarily with CCE although CVP is the more common IVR choice for that solution. It can also be used for building IVR-only self service applications.
Please remember to rate helpful responses and identify helpful or correct answers.
11-10-2012 02:25 PM
CCX Premium does, yes. They are the same software, the license keys just activate different subsystems.
Additional information on the features per license level is available in the CCX SRND.
11-10-2012 02:04 PM
11-10-2012 02:19 PM
So uccx include all ip IVR features, we don't need ip IVR if we have uccx premium?
11-10-2012 02:25 PM
11-10-2012 02:59 PM
Thanks for the information.
