Showing results forĀ
Search instead forĀ
Did you mean:Ā
40G Ethernet Expansion Module (PID: N9K-M12PQ) support which SFP
Pawan Raut
Level 4
Level 4
Nexus 9K switch module 40G Ethernet Expansion Module (PID: N9K-M12PQ) I know it supports 40G SFP. My question is that will it support 10Gbase-SR (SFP-10G-SR) as remote end devices only support 10G.
josedelpino
Yes, is supported but you need an adapter "CVR-QSFP-SFP10G".
You can check SFP compatibility with TMG:
https://tmgmatrix.cisco.com/?npid=137
