9200L Switch not boot from rommon mode
hafeezali
Hi All,
My Cisco Catalyst 9200L-24P-4G is every time booting up in rommon mode.
The warning display is:
WARNING: Bootable URL's in BOOT variable not found or exhausted.
Please check the ROMMON configuration or boot command usage.
I try to boot from the USB drive but it failed to load from usb drive
switch: boot usbflash1:cat9k_lite_iosxe.17.06.04.SPA.bin
boot: attempting to boot from [usbflash1:cat9k_lite_iosxe.17.06.04.SPA.bin]
boot: reading file cat9k_lite_iosxe.17.06.04.SPA.bin
boot: failed to load usbflash1:cat9k_lite_iosxe.17.06.04.SPA.bin (Aborted)
ERROR: failed to boot from usbflash1:cat9k_lite_iosxe.17.06.04.SPA.bin (Aborted)
I tried also the option using set commands with no success.
Neither it boots from the flash: nor from the usbflash0: or usbflash1:
Please check below the set commands parameters
ABNORMAL_RESET_COUNT=0
AUTO_SWITCH_CONSOLE_DISABLE=0
BAUD=9600
BOOT_DEVICE_MODE=catalyst
BOOT_LOADER_UPGRADE_DISABLE=0
BSI=0
CONSOLE_MIRRORING_DISABLE=0
MAC_ADDR=98:A2:C0:28:CD:80
MANUAL_BOOT=no
MODEL_NUM=C9200L-24P-4G
MOTHERBOARD_SERIAL_NUM=JXXX63XXXX
NO_CONSOLE=0
RANDOM_NUM=1587461955
ROMMON_BOARDID=0x4316
ReloadReason=packages.conf
SWITCH_NUMBER=1
SYSTEM_SERIAL_NUM=JXXX63XXXX
TEMPLATE=advanced
USB_DISABLE=0
boot=packages.conf
Any suggestions guys. Is it the case of RMA or can be resolved.
M02@rt37
Hello @hafeezali,
as concerned your USB drive what is the Filesystem?
Best regards
