9k vpc orphan-port mac-address learning
lukaszkhalil
Hello
I've just faced an issue with mac address learning by an orphan port connect to a VPC node (N9k).
I have dual side HSRP running on both: group 1 (SW1/SW2) and group 2 (7k-1/7k-1) in a particular vlan (10 in this example).
Strange thing is that both 7k learns SW1/SW2 hsrp mac address correctly (0000.0c07.ac02) but at the same time only SW2 see the hsrp group 1 correctly (0000.0c07.ac01).
Somehow SW1 does not learn 0000.0c07.ac01 via the port 1/48 from 7k-1.
The SW1/1/48 link works correctly because the HSRP is running though it and it works fine.
I've add a diagram which describe the topology.
Does anybody have an idea why does it happen?
Thank you in advance for any answer
Best regards
Lucas
follow
Sergiu.Daniluk
Hi @lukaszkhalil
I see some inconsistencies in what you mentioned about configured groups and learned mac addresses.
Can you share the cfg of SVI10 and show hsrp group X from all 4 switches?
Also, another question: N9K1 and N9K2 are configured in a vPC domain?
Cheers,
Sergiu
Sorry
I apologize. I made a mistake in the diagram. Of course 9k are running HSRP group 2 and 7k hsrp group 1.
SW1# sh run interface vlan 10
interface Vlan10
no shutdown
ip address 192.168.1.2/28
hsrp 2
priority 30
ip 192.168.1.1
SW2# sh run interface vlan 10
interface Vlan10
no shutdown
ip address 192.168.1.3/28
hsrp 2
priority 20
ip 192.168.1.1
7k-1# sh run interface vlan 10
interface Vlan10
no shutdown
ip address 192.168.1.12/28
hsrp 1
priority 30
ip 192.168.1.14
7k-2# sh run interface vlan 10
interface Vlan10
no shutdown
ip address 192.168.1.13/28
hsrp 1
priority 20
ip 192.168.1.14
Regarding the vpc, no, 9k are not running vpc. These are two orphan routers. The HSRP is "closed" through the 7k.
This is exactly the issue I have. Each one should learn the 7k hsrp independently on its uplink.
