cannot create VSM secondary
jowett_chris
hey,
i am trying to create a VSM secondary but for some reason it just won't work, i have filled out all the information including the same domain ID but when i boot up the secondary all i see is a different switch name.
when i run show mod, i dont see the secondary in the list of VSM, does anyone have any troubleshooting ideas
thanks
6 Replies 6
lwatta
Chris,
I would do the following.
Take a back up of the primary VSM just to be safe. If it's on ESXi, copy run start, shut it down and clone it. Shouldn't take more than a few minutes.
For the secondary try creating it on the same ESXi host as the primary VSM. Assign the nics to all the same port-profiles as the primary.
See if that works.
louis
Hi Louis,
Sorry for the delay, been out of the office
i have tried to create on the same host but no joy it never finds the primary VSM.
i get this error
SIOCSIFFLAGS permission denied
not sure what that is doing? any ideas?
thanks for your time
hi chris,
what is the output of the command "show system redundancy status" ??
the primary vsm should have the output
Redundancy role
      administrative:   primary
         operational:   primary
the secondary
Redundancy role
      administrative:   secondary
         operational:   secondary
If there is "standalone"
you must enter the command "system redundany role primary" for the primary vsm
and "system redundany role secondary" for the secondary.
thanks that command - system redundany role primary did the trick
thanks alot
worked for me too, thanks.
This also fixed the problem for me.  Thanks!
