cisco 9300 switch stuck ssh using tera term
vinoth13.c
when we're using tera term to take ssh on cisco devices it stucks .
is there any solution or work around to fix the problem.
model : 9300
Sergiu.Daniluk
Hi @vinoth13.c
Are you talking about nexus or catalyst? Are there any other connections which work ok (telnet, console)? Does SSH work from other terminals?
Cheers,
Sergiu
catalyst , we have tried only ssh . We tried through putty its working only its stuck while using tera term.
Sergiu.Daniluk
Hi @vinoth13.c
For catalyst switches there is a different community thread: https://community.cisco.com/t5/switching/bd-p/6016-discussions-lan-switching-routing
From your description, it looks like a teraterm (application) problem and not switch-related problem or config issue. I would suggest you also search on google about this. Seems there are quite some topics opened on this matter. Also, make sure your ssh client (tera term) is properly set up: https://ttssh2.osdn.jp/manual/4/en/menu/setup-sshauth.html
Cheers,
Sergiu
