ā08-15-2018 10:55 AM
Hi - I run a lab and noticed after upgrading that the Cisco upgrade to 9.2.1 from 7.0.3.I4.8a where it was corrected in the below bug, seems to exist in the new 9.2.1 code. Before the upgrade to 9.2.1 the fans were running at 4000RPM , after the upgrade they started to run at 9000RPM. Anyone else experience this issue?
https://quickview.cloudapps.cisco.com/quickview/bug/CSCva93139
ā08-20-2018 03:20 AM
I could not find anything internally being reported yet. Could be because the 9.2.1 release just came out.
I may try to squeeze in some time to test this and revert back. However I also recommend opening a TAC case for this issue.
Raj
ā08-20-2018 10:07 PM
There is a known issue related to this. we are working on this and fixing it in next NXOS release.
